Passenger Jack Point Smashed
Is there any way to replace the jack point on a 1986 944 Turbo? Mine looks like something hit it from the rear and it no longer has the oval shaped hole. It's more of a "D" shaped hole now. I was able to open it up a little bit to allow the tip of the jack to go into the opening, but it is no longer level and causes my jack to contort in ways that looks like it is going to twist the jack til it eventually breaks...
It kind of looks like that jack point is riveted on or something?
Anyone know if anything can be done about this?
I'll try to get a picture of it when I get home.
See those bolts that are coated with underbody coating? Clean off the coating and removed the jackpoint from the car. It's the mount that's bolted to that's spot welded on the car.
Humboldtgrin, you were absolutely right. That thing does come off after pulling out four 10mm bolts. Thank you for that tip! I did have to partially remove the plastic rocker-panel ground effects to get to the outside two bolts.
Ok, so with the help of an old bearing, some different sized sockets, a 12 ton hydraulic shop press (that I bought to do the front wheel bearings on my 2004 Infiniti G35 years ago), as well as a bearing race from said Infiniti wheel bearings - that I knew I had saved for some reason, I was able to work this thing back somewhat into shape. It's by no means perfect, but I think I at least have a fighting chance of changing a tire on the right side of the car on the side of the road if I needed to.
If anyone knows where I can get the replacement part, please let me know. I think I'd like to replace my handywork with one in the original condition.
Much thanks guys - here's some pix I snapped along the way...
Before:
After:
This bearing race from my Infiniti G35 fit perfectly inside and I kept that in there so the part would retain its outer shape while I pressed different sized sockets thru to enlarge the hole.
Here it is on the jack - sits on it fairly well - much better than before!
Before:
After:
I'm sure Lart could send you as many as you want -- especially on a part like this that probably ends up in the crusher more often than not. Nice job on the fix up though.
By the way, if that's the jack you use, forget the mount and get thyself to Harbor Freight...
The middle one bolts...?
LOL, that's news to me, never had to mess with one honestly and I have seen the rear take hits where you can change just a portion but I could have sworn the middle on these cars was welded.
The 968 (at least one my son races) doesn't even have the center one so I made some out of sheet and box and welded them on for central jacking that allows both side tire removal at the track.
You would have had to remove seat and carpet to do so because it would easily catch fire.
Mine was a stripped race car.
Chalk one up for Humbold-G...!
T
