DME compatibility question
Can I use a DME from a regular 944 and use it on a 944 turbo? Assuming, of course, I install the appropriate chip and it has the correct number of pins. Thanks...
The Bosch part number is almost exactly the same as the 951 DME, except the last number, or last two, are different.
