Intercooler upgrade / modification (Ebay/Chinese vs Garrett)
Professional Hoon
Some bad news, I took it for a drive to get onto some boost. Drove back in and noticed a few drops of coolant on the floor. Back on the hoist and i put compressed air into the cooling system, While pressurising the system, the radiator started leaking coolant quite heavily. I did use im regulated air from the compressor, and im not sure how much psi i put into it, but it wasn't to much. enough to find a leak. So i'll be putting a new radiator in. Probably not OEM but a larger PWR core. I'll be giving them a ring tomorrow and discuss what i can do. So there wont be any back to back tests that are comparable if i get a more modern and larger radiator.
Professional Hoon
I'll end up buying a new core and make my own end tanks. It'll be a little more involved than the IC tanks as there will be bungs ect welded on.
Im not sure how thick our stock ones are, but PWR make radiators for the 944t which are 55mm thick 2 core. It appears to be thicker, but not sure.
Professional Hoon
Im going to pull the AC condenser out and eventually pull the AC. i dont use it. i never drive it when it's hot outside. that will give more air to the radiator also.
