Chasing an oil leak for 2 years, , GOOD MORNING
I haven't had this specific leak but my best guess from your photo would be that the 2 crush washers for the large banjo bolt got deformed and are not creating a tight seal. Replacing those will likely eliminate the leak.
Dave where can I get these washers.?..Also Torque to tighten. ..THANKS
Is that a crack just below the fitting? You can seal it with Loctite 290 without removing the pan if you drain the oil and follow the Loctite directions.
Here's the seal ring (26x31x2):
http://www.pelicanparts.com/More_Inf...049-30-INT.htm
