Miss firing while cruising 2-3k rpm
Professional Hoon
So i've finally got my car back together after bending a 2nd set of valves.
It drive flawlessly before it all happened.
Apart from the valves getting replaces, the pistons got cleaned up and a new set of gaskets and fluids.
I have replaced the spark plugs & leads. That's it
I am looking at it's either 1 of the 2, but the miss fire stops at load.
It's not a big missfire, it's like i can feel the car very slightly jumping while cruising. As soon as i give it throttle, it goes away and pulls. Car feels the same as it did previously except this missfire.
The sparkplugs are my standard NGK ones i use. IICR they're BPR7
The leads are BURU but not the porsche ones. They are the ones that the leads are pushed and crimped onto the plugs. I know this because one fell off and i pushed it back on. I'm thinking that could be the issue. I think i have my old ones (i know one is broken) but i can replace the one that came off.
What im thinking is though, if it's 1 lead that's the issue, shouldn't it missfire more at higher RPM or be more noticeable with more load?
Professional Hoon
The gaps on the S&R sensors are good. i marked them before taking the housing off and put back on the same spot. And when installing (new) them, i gapped them properly per manual. wouldn't this cause an overall issue, not just part throttle cruising?
It's a very low missfire, you need to pay attention and look for it to notice it. I thought about data logging it, but unsure how. RPM doesn't move. neither does the vacuum.
Professional Hoon
i have a known good TPS as i have changed it. But i changed it before it all happened and it had 0 issues.
Tonight i'll try my ignition leads for a piece of mind.
Professional Hoon
I had my rotor break once, that was missing quite badly top end
Professional Hoon
Im not sure if it's a missfire now. I dont know how to put this in words. But when i changed my cam to this big cam i have, the car would jolt? like it'll want to go accel then stop and continue doing that, so feels like it's jolting and that'll happen while cruising on a freeway or something from time to time. To stop it i just accel and it'll go away immediately.
But now i can feel it slightly while cruising.
I had Josh make changes to the tune and it did help. I know there's something causing it at the moment, I'll just have to go though and double check things now.
