Took off the head, need advice on how to proceed
Rod bearings were done 6 months ago.
The machine shop told me that value guides are also due for replacement.
I am waiting for the value guides to arrive and after the value stem seals and valve guides are replaced, I will close the engine.
I have the head gasket kit + I took the opportunity to do the belts (only two years old, in good shape) and rollers.
I am also doing the front end seals (balance, cam and crack shafts), water pump replacement and the oil filter housing and OPRV seals.
Is there any other seal job to get done while I am in there?
