Central Locking - what can cause these symtoms?
Car is a 89 951, ex-California if that should matter (saw that fuse 17 mentioned diag.connector for Central locking, USA only???). This is what I have found:
There are many wires to the actuators, how can i test if the actuators are really getting Power? And are there a way to test the Control module?
- Fuse is fine
- Both doors will Lock and unlock With the key
- Locking one or both of the doors activate the alarm (probably unrelated to the Central locking?)
- Locking either side of the doors will not Lock the other side
- Unlocking either side of the doors will not Unlock the other side
- With ignition on, pressing the Central locking button will produce two clicks from the Control module, but no locking or red light in the switch
- With ignition on, locking one side will not produce a click from the Control module but a red light in the switch
- With ignition on and both sides Locked, unlocking one side will produce a click from the Control module, red light stays on.
- I have removed the PS doorcard and moved the actuator, it does not seem to be sticking.
