Weight reduction ideas
Hmmm... Not sure why a 944 hood would weigh more than a 968's. I weighed mine, and it was nowhere near 40 lbs. Yes, it's very awkward, making it seem like it weighs a ton, but I seem to remember it being in the 20's, low 30's tops. And I was disappointed at how heavy my fiberglass hood is - somewhere in the high teens, as I recall. So, I think I only saved about 10-15 lbs with the fiberglass hood, but it was a long time ago, so my memory is fuzzy. A carbon fiber skin held down by hood pins at the corners would be the ultimate, but again, prohibitively expensive, since a 968 CF hood would be a custom made affair.
I have a car with fiberglass fenders and hood.
Doors are so light once gutted properly, it's not even worth trade off for fiberglass.
More weight than the difference can be taken from elsewhere for free.
The factory rear 1/4 windows in glass weigh next to nothing...., not worth it either IMO.
T
Nicely thought out and well put. Yes, safety always has to come first. Also, it's important to keep things in perspective. I just use the car for sessions at the local driving academy. I look at it as a training tool for my ultimate goal, which is to participate in an arrive-and-driver series (when my kids are out of college) like the Simraceway series at Sonoma International Raceway. I just want to strike a balance between a car that is capable, responsive, and can pass other cars at least as often as it gets passed (there's a lot of high dollar hardware at Driveway Austin), without costing a fortune to run. At this point, I'm just looking for any items that I may have forgotten about. The lexan rear hatch and a lighter passenger seat may be the next, and possibly the last, things I do in the weight reduction department. Unless my friend with the trick Miata adds a turbo - then it's game on
SP2 car at right in pic is 2400#
T
Unless this is a pure track car with a proper cage I wouldn't risk going to non OEM doors. I had experience with a pretty heavy impact crash on a track with the stock doors and they provided a lot of protection. With f/g doors you'd be at risk of serious injury if the worst happened.
Do you (or anyone else who has done this) have any pictures of how you gutted your doors? I know that sounds like a dumb question, but I still drive my car to and from the track, and on occasional errands when none of the other cars in the family are available, so I would still need some windows that at least somewhat functional, however manually. Plexiglass would be fine, even preferred due to their light weight. So, my question is, how do you replace the stock glass windows, motors, regulators, etc., with some sort of manual set-up that looks at least somewhat convincing to prying eyes in a grocery store parking lot? And what is the heaviest part of the doors that get removed when you gut them, or is it the combination of the above mentioned parts that add up to a significant amount of weight? Thanks.
Yup, will pop you up a few pics this weekend. Can weigh a stock door vs one of my gutted doors but it'd be a few days..
The weight difference is drastic.
You would have to select a Lexan/plexi thickness and then make channels for it to slide up/down in.
T
T
Light Doors full stock function
Hi.
With my car (968 CS) I wanted fully stock function and look but as light as possible.
My doors have gf outer skin with weight savings made to steel inside and to manual winding mechanism which is very heavy stock. Further I have hardened scratch resistant lexan windows from plastics for performance in the UK. Overall weight is about half of stock door but still look fully
stock and have winding windows. My car also have full aluminium cage.
The winding mechanism I lightened myself which together with the lexan windows shaved 4,5kg per door. If I remember correctly the stock clubsport door weighed 31kg versus my doors at 13kg. Look and function is identical. Ofcoarse safety is not god this way byt together with my cage it is ok
If you guesstimate the door exterior to be 1 sq yard, or 3 feet square, 4.5 lbs of sheet metal thereabouts.
Same area of fiberglass cloth, let's say 6oz cloth, which is just that 6oz per sq yard...., three layers of just cloth is going to be 18oz cloth.
An accepted formula, cloth saturated, weight of resin is 2 x weight of cloth, so for that area, 36oz resin minimum.
So, 54 oz of material, not counting corner reinforcement, etc, is 3.375 lbs.
1-1.2 lbs savings at a location of the car where weight savings has the smallest advantage.
Now when you get rid of the entire door for a fiberglass or carbon replacement, this is when it pays off because many portions of the door are double and some even triple thickness sheet.
T
IMO, no, not worth it. The metal of the skin is about .040", which is around 1.5-1.75 lbs per square foot.
T
T
My doors give you the comfortable feeling of a stock door at 13kg a side which to me is ok.
Personally I dont like not being able to wind the windows down.
It is all a matter of personal preference as always.
Thanks. Why do you have to make new channels for the plexiglass to slide in? Why not use the stock channels that the glass slides in? And what keeps the plexiglass in place? And what about the interior door latch - is there a way to retain that with a gutted door? I guess that isn't essential - I suppose I could reach out and open the door from the outside, but keeping the interior latch would make it more convenient. Sorry for all the dumb questions - as you can tell, I've never done this before, and am debating whether it's a good idea in my case. Again, my car is primarily a track toy, but I drive it to and from the track, which is about 20 miles from my home, and occasionally make stops on the way home, so I'd like to find a balance between weight savings, a stock (from the outside) appearance, and some rudimentary semblance of function. I don't need to retain the ability to crank the windows up and down, but I do need to be able to to leave the windows in place so the car looks secure to the casual observer.
