Oil squirter install in 2.5 block
Did anybody installed oil squirters in a 2.5L engine block? I wold like to find out where to drill the holes for the squirters. I made a sketch how of how I think they should be installed but I'm not sure if it's corect. If there is anyone who know what is the correct way to install the and would like to share I would really apreciate.
No. The machine shop will do it, but since I can not find anyone who has experience here with this engines I need to make a sketch for the machine shop with what I want. The factors I have taken into consideration when I did this sketch was the piston shape ( which is mahle powerpak) and engine block ( I tried to avoid creating zones with thin material on squirt bore exit area to prevent weakening the block).
How modified is your motor and what are your intentions? Are they totally necessary?
The 968 pistons are notoriously lighter (had factory squirters), especially the Mahle at 490 grams compared to the 944T at 520. My stock KS 944S pistons at 4mm smaller bore are 540 grams, no piston cooling squirter.
It makes sense that the factory lighter piston probably has a thinner crown and may have needed the oil squirters.
It's definitely not a movement of the ring closer to combustion because all 944 family top rings are pretty low.
Personally, I wouldn't tax the oil system any more than it is if I didn't have to.
If I knew the minimum requirement of the balance shafts at XX rpms, I would plug and orifice the feed to those to limit delivery waste.
The poppet could have a side benefit though, may remove aerated oil before it makes it to the rods.
If you cool the wrist pin, you are also taking heat off the piston and there are some close to free ways to do that.
An escape notch at the upper side beam of the rod would sling 360 degree, already escaping oil from the rod bearing and make it useful.
Drilling from the scraper groove to the pin would send oil directly to the pin on the down stroke.
T
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If you do decide that these are necessary (and I don't believe they are unless its a full on track engine) then make sure that the head is located inside the oil groove in the block. The head has a flange on it so the hole is not super critical in diameter, the bearing shell will trap the oil squirter in place if it moves. With the right diameter drill bit you could do this with a hand drill (I use a milling machine - but hey, I'm like that!)
Don't fret about the aim - the piton is a moving target and the oil is spraying everywhere.
Registered User
Hi, All , why not just drill into the main bearing housings, a .5mm hole on an angle . Do not need to make anything. Main bearings are grooved so just need to "hit" the groove. Thats what mantis does when needed.
I don't know if they are totally necessary, probably not, after all I know there are track cars without this mods and run fine, but since they cost mostly some machine work and they were also adopted as upgrades by the factory I thought "why not?".
Wondering, this feature is usually added when trying to lighten a piston for performance because the crown would be thinner, thus more heat.
T
T
I would say as a generalisation more cooling is better...but in your case I wouldn't bother. We had issues on a past motor with oil pressure loss. We're 95%+ sure it was due to too much oil going through the squirters being retro fitted.
These engines definitely survive hard track duty without them.
Most of my focus is on how I can improve and gain some headroom with oiling, not ways to bleed some of it off....
Restricting supply to balance shafts and using the #3 main to get additional supply to the #2 & #3 rods seems viable on paper.
T
Yep, as I mentioned above, that'd be my fear of using them.
Most of my focus is on how I can improve and gain some headroom with oiling, not ways to bleed some of it off....![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
T
T
