Final WBo2 sensor question
Oh I haven't yet-
Will prob put where you did little after the down pipe. Do you have a pic?
Also, I tried running the WBO2 cable... no dice
Did you run the white connector up the entire wire guide boot in the engine, push the firewall boot over and run it between the black boot and the metal frame, or do something different? Every place I've tried running the dang thing is wayyy too tight. Any pics of that?
Chris,
I was an idiot and didn't bring my camera to the shop...so no pics
And I ran the cable through the boot....not between it and the metal. I made a small incision in the patient's upper boot (master surgeon speaking here :-)) and pushed it through....it was still a pain to get it through however
hey guys...
with these kits can you pass the the new O2 sensor or cable with connector past the heat shield down to the exhaust pipe bung (factory location) I remember having to cut the endoff the factory O2 sensor 'cuz it was too large to pass through.
