OBX Headers
OBX Headers
Looking for input good/bad. I need to replace my stock manifold gaskets and considering headers. Is the price of the OBX brand to good to be true? Also, Ebay listings show fitment for 88-91. My car is a 87 Turbo and looks to be identical to my 88 Turbo I recently traded. I.E. 2 piece crossover pipe, etc.
I found in life you get what you pay for and sometimes not even that. I have heard they work, I have also heard they warp. I would think they would work for a stock setup, at least for a while. If you want a higher HP engine then I recommended a header from one of the following: Billy Boat,Speed Force Racing,Lindsey racing.
Basic Sponsor
10% OFF for listers , if you follow my threads these are 30k miles headers I have auto check results.
http://www.ebay.com/itm/Porsche-951-...item3aeab82c29
Will last more than obdx for sure, there is a thread here where some listers tested the headers and cracked shortly
https://rennlist.com/forums/944-turb...ml#post9882526
My OBX headers are done. I only used the headers, not the down pipe or waste gate tie in that comes with the kit. This is after 2 seasons, approximately 30 events, and the street driving to-and-from, and this is the result, leak on one exit:
Major cracking along the line of welds on another exit:
I knew about the leak, I could here when it happened at the 2nd last event of the season. The cracked welds were news to me.
Maybe the OBX headers would last better for street use, who knows.
Any thoughts on what I should do next? $300 for another 2 seasons, or Lindsey Racing for more money and hopefully more time?
Unless your racing the car, Tracking the allot and running higher than normal boost, Id leave the headers alone.. The issue with the factory headers is the angle that no 4 hits no 1, doesn't "Flow" very well and compounds the well known cyl4 headgasket issue due to high temps and pressure.. But if its just a street car not an issue..
It would be interesting to see dyno results of all the different headers... I would bet factory to aftermarket is less than 10hp different..
The above pictures show an Undercut on the weld indicating that there is little to no filler rod used in the weld making it weaker, Add to the fact that stainless and alu have different expansion rates and that's why it cracked. There is a reason for the 944 having the "updated" headers with the expansion joint .
There's a bunch of threads on OBX headers - consensus seemed to be that you get what you pay for, and that you need to spend time cleaning the slag from inside. Re-welding probably necessary.
I looked into all header options a few months ago, including having the originals repaired.
The Porsche headers are alloy 625 (Inconel). Some people claim success welding these, but to do it right so it will last is technically challenging (and $$$).
304SS is not really suitable for Turbo header application. Inconel or 321 stainless is what you want for high exhaust temperatures. 304 welds will crack due to 'chromium precipitation'.
I ended up going with the SpeedForceRacing Stage 1 header with 321 SS option. Very happy with the quality and fit. Took longer than expected to arrive though ~ 2 months.
Lart - Did you pressure test those headers? I bought a set off eBay from someone else and they claimed leak free and low miles. They looked great on the outside, but leaked badly once tested.
Now I have two sets of Turbo headers. This winter I will look into getting these repaired properly.
Did you make those adapters yourself? Looks like a good idea.
Yeah, I had them laser cut from 1/4" carbon steel. Just need to drill a center hole, but you could add one into the design.
Here's links to my AutoDesk Fusion 360 designs:
http://a360.co/2ueWlEJ
http://a360.co/2tLd8vL
Dimensions in mm.
Dimensions in mm.
Basic Sponsor
Very nice thanks
Dimensions in mm.
Dimensions in mm.
