944 & 944S Forum 1982-1991
1983 944 won't start
Old 04-17-2017, 01:50 AM
Jrees
6th Gear
Jrees's Avatar
Default 1983 944 won't start
So I was driving my 1983 944 on Friday after having it sit for about 4 days. Started up like normal drove fine. Got back to my dorm, powered off the car to grab something and when I got back to the car the engine fired then died. After this, I parked it and tried it again but it would just crank. Let it sit for the night and when I got back to it in the morning it turned over for a second and died again. After this still just crank when I turn the key.
Inspected the DME relay and it looked OK but I have a new one coming in tomorrow. What else could be the problem? I do have tac bounce so I don't think that it is the reference sensor.
Old 04-17-2017, 04:26 AM
mel_t_vin
mel_t_vin's Avatar
First order of business...verify 1) timing belt is intact, 2) spark at the plugs, and 3) fuel at the injectors.
Old 04-17-2017, 11:46 AM
Schmooey
Schmooey's Avatar
What relay did you check? IIRC, only post-1985.5 cars have the DME relay, and those of us with earlier cars do not have this.
But, first place I would check would be the distributor - easy to open and look. Rotor clean and OK?
Old 04-17-2017, 02:53 PM
ECU Doctors
Former Vendor
ECU Doctors's Avatar
I always tell people to check their Crankshaft Position sensor and their Speed Position Sensor since these can sometimes cause no start conditions.
See video we made on how to check these sensors:
Old 04-17-2017, 04:23 PM
Jrees
6th Gear
Jrees's Avatar
Timing belt is intact(thankfully), will check spark and fuel later today.
Old 04-17-2017, 04:24 PM
Jrees
6th Gear
Jrees's Avatar
What I meant was the Fuel pump relay located in the number II position under the dash.
Old 04-17-2017, 06:58 PM
Jrees
6th Gear
Jrees's Avatar
All checked and working
Old 04-17-2017, 08:55 PM
968workaholic
968workaholic's Avatar
Sounds like a bad fuel pump
Old 04-18-2017, 03:29 AM
mel_t_vin
mel_t_vin's Avatar
You have verified spark at each plug and [spraying] fuel at each injector while cranking?
If so, then the only other components missing are timing and compression.
Old 04-18-2017, 03:33 AM
mel_t_vin
mel_t_vin's Avatar
Incorrect...944/1 fuel pump relay and 944/2 DME relay are the same part [944.615.227.00].
Old 04-25-2017, 11:09 AM
Mr Exotherm
Mr Exotherm's Avatar
The last time my '83 944 had this problem it was the crank sensors. Don't discount that possibility.
Quick Reply: 1983 944 won't start
