thermostat temperature rating
I need to replace my thermostat and the work will not be the issue. For me I never really know what is a good temperature for the thermostat to open. When shopping for a new thermostat I notice there are many different options to the temperature rating on to when the thermostat will open. Any thoughts on to what is best or recommended by Porsche?
I was thinking about going to a low temp but I decided to go with the next thermostat up. It says it is a 180° rating. Hopefully it'll cool her down a bit.
Rainman
944's don't run hot if everything works as intended.
The stock radiator and fans are more than sufficient...if you are running hot, you have a problem somewhere, plain and simple. Unless you live in the desert where it is regularly over 100 degrees? (When I lived in such a place I solved my "warm running" issue by adding an external oil cooler)
T-stat temperature doesn't really do anything, but fan switch will. T-stat just means the minimum temp inside the engine before the radiator sees circulation, but doesn't set any "ceiling".
Running the fans longer will work though.
