944 & 944S Forum 1982-1991
1983 944 alternator problems
Old 08-19-2014, 01:57 AM
keiffer
keiffer's Avatar
Default 1983 944 alternator problems
Could anybody help me out that has had experiences with alternator issues?
Old 08-19-2014, 11:29 AM
V2Rocket
Rainman
V2Rocket's Avatar
what problem are you having?
Old 08-19-2014, 01:27 PM
keiffer
keiffer's Avatar
It won't hold charge and I believe it burned up some wiring as well. Do you have any tips for taking it out?
Old 08-19-2014, 08:10 PM
plumbum
plumbum's Avatar
What is the Alternator output? Not holding a charge sounds more like a battery issue
Old 08-19-2014, 11:02 PM
fred27
fred27's Avatar
The diode failed in my alternator and burned the wiring harness and damaged the battery.
Old 08-20-2014, 11:41 AM
keiffer
keiffer's Avatar
Fred that sounds about right for mine as well. Did you replace it yourself?
keiffer
keiffer's Avatar
Plum 90
Old 08-20-2014, 01:57 PM
V2Rocket
Rainman
V2Rocket's Avatar
alternator is easy to replace in the 944...
remove the airbox (2 bolts in back below brake master cylinder, 3 nuts holding front bracket to radiator frame, one hose clamp for AFM, one AFM wire, and the breather hose to the side of the box)
remove the 13mm nut and 8mm nut on the back of the alternator, remove the wires.
bottom bolt IIRC is 13mm head, might have a nut on it. top bolt also 13mm, should have a nut on it as well, then just wiggle the alternator until its free.
should be back to a running car in about an hour.
Old 08-21-2014, 11:59 AM
keiffer
keiffer's Avatar
Thank you a lot rocket
Old 08-22-2014, 12:01 AM
fred27
fred27's Avatar
Sorry for the late reply keiffer, and props to v2rocket for the alternator remove and replace instructions.
I removed and refitted my alternator and got it repaired at an auto electrician.
Good luck with yours.
Regards
Old 08-22-2014, 12:43 PM
ibkevin
Defending the Border
Rest In Peace
ibkevin's Avatar
Buy an adjustable regulator kit, pull the alternator, inspect and clean the moving parts then check your BATT/ALT/STARTER wiring and connections.
Simple stuff.
Old 08-22-2014, 09:59 PM
keiffer
keiffer's Avatar
Thanks I'm working on it tomorrow if weather permits
Old 08-24-2014, 12:13 AM
kens_74911s
kens_74911s's Avatar
Default Alternator
If you think you need an alternator, I have one you can look here.
http://forums.pelicanparts.com/porsc...g-harness.html
K
Old 08-26-2014, 12:35 PM
keiffer
keiffer's Avatar
How much is shipping what country is it coming from
Old 08-26-2014, 12:55 PM
kens_74911s
Default Alternator
My stuff ships from North Carolina 28387 Zip. Alternators Ship in USPS Flat Rate Medium Box $12 .
K
Quick Reply: 1983 944 alternator problems
