help ... no spark
help ... no spark
Good day everyone... I'm at a loss... I am in the process of prparing a 1987 944 for track purpose only.. just before taking the car apart in the fall.. I stripped all the wiring that was not necessary...and mad sure it runs... Now, after the rebuild, I get no spark... I have replaced both flywheel sensors and the gap is good, I have followed all the testing procedures from the Porsche repair manual...eerythings checks up good... I have battery voltage on both side of the coil, but never a trigger to the distributor.... any thoughts ??
or the ol' DME relay
or Brian's alarm problem here...
Originally posted by Perry 951
I feel like I just had a baby... 951 has come alive and sounds great! Once I got the mixture good enough to get out of the car, I cycled the motor from idle to 2500 for 15 minutes while standing in a cloud of smoke as it burned off all the oils.
I have a nasty oil leak.. I think from one of the balance shaft seals, but could care less. I can fix that in no time at all. I am going out to pull the covers when it cools down to see what's up.
Many thanks to Andy for letting me use his DME and KLR. At the same time I also bypassed the alarm with pins 1 and 4. I will swap in my DME later and see what happens.
Tip for the future (and I will post this soon, and thank you Bader$), 87 and earlier cars, for the alarm bypass, it is 1 and 4 only. Later cars, jump 7 and 8.
Thanks again to everyone on the list, you are a major reason this baby is here.
Well it was a bad contact at the fuel pum in the fuse box... thank's for the replies...
I now have another problem... with oil pressure....I opened another thread on it... feel frre to give your coments,
Thx,
Thx,
glad you found it...and yeah the alarm for the 944 and the 951 (of the same Model Year) are the same
here is more on it from Brian:
Since there is little in the archives on this, I am gonna post what I found.
86-88 Cars
The Control box is above the DME in the passenger compartment. It is a 3"x5"x2" black box with blue lettering, and has 2 connectors. One connector has 2 wires and is the output of the control brain. The other is an 8 pin connector for the various inputs. To disable, unplug both connectors and with a jumper wire, jump pin 1 (green) to pin 4 (red/black). The early cars do not have a fuse or relay to bypass the alarm control.
89 and later cars
There are 3 components to the alarm. The control box, a fuse in the main panel, and also a relay in G18. Assuming the fuse and relay are fine, remove the connectors as stated above. (control box also above the DME) Jump pins 7 and 8. If it still won't start, try jumping 4 and 6 as well.
Since I do not have a later car, I do not have the wire colors, but other posts have said this procedure works just fine.
Happy disarming!
86-88 Cars
89 and later cars
Happy disarming!
