My 1991 944S2 eats batteries
After adding Iceshark's full boat package with lights, alternator, and wiring upgrades my original battery worked fine to two years. That battery then died, and I replaced it with a Duralast Ultra (Autozone 'high end') and it lasted a few weeks. Taking it back, they said a plate in the battery had been burned up due to high current. Two more Duralast batteries later, each lasting a few weeks, and they gave me a full refund.
I then went with an Interstate battery. That seemed great, but after I stored the car for a few months it has an issue. If the car sits for a weeks with no driving, the battery is dead and needs to be recharged.
Current draw when parked it 91 milliamps. What do you think the issue might be here? Where should I start investigating?
thanks,
Bryan
thanks,
Bryan
had a very similar problem (same car!) and all I can tell you is that right after it started happening, my driver's side door lock crapped out...a small spring from inside the door lock mechanism jammed it and I think it was messing with the alarm...setting it off. I guess I should mention that the PO disabled the alarm horn....so I had no idea this was happening until one day when I charged up the battery and noticed the interior light flashing and heard a clicking from the passenger foot-well.
Long story short I had the power lock solenoid replaced in the driver's door and have been fine since.
