Huge negative camber on 87' 944
Having negative camber issues with my 944. It had turbo brakes on it when I bought them which I replaced. I tried adjust camber but it's maxed out. The car is not aligned at all.
It went something like this:
- replaced front spindles;
- replaced front brake calipers + rotors;
- replaced front spring/struts;
- replaced front wheel bearing.
The camber is pretty bad and the car is very hard to steer.
Any ideas? Thanks!
Any ideas? Thanks!
walfreyydo (07-31-2023)
I concur with Spencer, you may likely have early offset spindles/hubs. Those did not come with ABS so they mount further in.
The fix would be to get spindles/hubs from an 87 or later car, preferably an S2 or turbo. I am unsure if spindles/hubs from a 87+ NA (non-turbo/S2) car will work with the Turbo rotors, maybe someone else can chime in.
