Pre ABS offset vs post ABS offset
Does any one know what is the difference between Pre ABS offset wheels + post ABS offset wheels????
If i was to fit pre abs , to a post abs car WHAT would happen?????
Would they catch the arches etc?????
Also
What are the correct offsets of both cars ?????
Yours hopingly
Dave W.
Also
Yours hopingly
Dave W.
23.5mm for 1983-1983 and 52mm for 87 on and they're not interchangeable. Mount the 23.5 on the later models and you push tires out into fenders, put 52's on pre and you push the tires in too far. Don't even think about it.
what I don't know is: what year is "pre ABS"??...if ABS was offered AFTER model year '87 and the wheels are MY '87...then no problem.
just don't use '86 or earlier
I took a quick peek at Kevin Gross' FAQ..."87 model year, ABS anti-lock brakes became an available option"...so 'pre ABS' is also the older offset years of 83 thru and including 86
