Starter issues
I walked out one day to my car and found that it did not want to start. The starter would simply click and hum. After some messing around with it, I found that the starter would only crank the engine if, and only if, I removed the alternator wire from the starter. For obvious reasons, this cannot be a permanent solution. Does anyone have any ideas about what the next step is? Will I need to replace the alternator or is the alternator wire probably grounding out somewhere?
