944 & 944S Forum 1982-1991
944S - Vs - S2 Gearbox Ratios different?
Old Apr 29, 2020 | 04:47 PM
GPA951s's Avatar
GPA951s
Default 944S - Vs - S2 Gearbox Ratios different?
I pretty much just deal with Turbos so when it comes to S2 stuff and 944S I am clueless... are the ratios Different between these boxes? Reason I ask is that I have a 944s trans laying in the woods and I know someone who needs a trans for an S2... Thanks!
Old Apr 29, 2020 | 07:23 PM
V2Rocket's Avatar
V2Rocket
Rainman
the 1-5 should be the same but the R/P is a little off - S is 3.889 and S2 is 3.875. S2 supposed to be stronger as the pinion is bigger.
Old Apr 29, 2020 | 10:22 PM
GPA951s's Avatar
GPA951s
Oh Cool well he has nothing to loose then if I give him the box, even if he gets a year out of it and Grenades it... LOL
Old Apr 30, 2020 | 07:30 PM
jem60's Avatar
jem60
Default s vs s2 gearbox
S and s2 have identical 1-4 ratios. As V2 noted the final drive is slightly different. 5th on s2 is slightly longer than S box. S box 5th is same as NA short 5th. S2 box 5th is about 1/2 way between short and long 5th on NA box. Ring and pinion on S box is same as the S2 and Turbo boxes.
Old May 5, 2020 | 09:36 PM
craigmakes321's Avatar
craigmakes321
I have an "s" transaxle with LSD in my s2, no difference - except for the LSD!
