Clutch Stalling problem
I wanted to start a new thread on this issue I am having. I pulled the car into the garage to change the TPS and then when I went for a test drive it would stall when trying to take off. I would push the RPM past 2000 RPM and slowly release the clutch and it would still die after the clutch was nearly pulled out completely. I played with the TPS and it didn't change anything so my guess is the TPS I replaced was synchronized properly to the throttle. It seems no matter what RPM I try to launch the car when the clutch is being pulled out it will stall. Please help so I can finally drive this thing.
