1988 porsche 944s
1988 porsche 944s
I just bought a Porsche 944 , I am trying to replace the engine gaskets but I do not know if have to put my engine In tdc before removing the belts any help is a appreciated thanks .
Yes, you always should have the engine set on TDC before removing the belts. Use the timing mark on the flywheel, viewed through the hole in the top rear of the engine block. Before you remove the belts, you can initially set it to TDC using the cam timing sprocket marks, then verify it by locating the flywheel mark. A flywheel lock is a plus but should not be needed if you don't need to remove the crank pulley to replace seals.
What is your skill level? Do you have a Haynes Shop Manual? Good tool availability?
Good Luck to you!
Good Luck to you!
With the transaxle out of gear, use a big ratchet (I used a 24" ratchet handle) to turn the main crank bolt on the front of the engine. Be sure to turn it clockwise! This will, of course, turn the flywheel, and you can peer in through the inspection hole on top of the bell housing to see the TDC mark. Another mark to check is the notch on the flywheel; this notch is located around the 7 o'clock position on the flywheel from the perspective of the driver's seat. Of course, you'll need to be underneath the car and have the starter removed in order to see this notch. The more TDC marks you can line up, the more confident you can be that you've got it set properly. You will be MUCH better off with a flywheel lock and a proper tension gauge (I'd recommend ArnnWorx, definitely not a Krikit-style "gauge"). I did this job without any other special tools besides those, and both of them were absolutely worth the money. Read through the procedure over and over until you're comfortable with it, familiarize yourself with the tools, take your time, and you'll be fine.
Post #11 in this thread was incredibly helpful to me when I did my belts: https://rennlist.com/forums/924-931-...ming-belt.html
This photo is a nice reference: http://2.bp.blogspot.com/-mRux7pnbbu...orsche+944.jpg
