Ranger quick jack?
Yeah, I bought the quick jack 5000SLX last year after various comparisons. Further, I bought the factory “extenders” which stretches the lift and allows me to lift my Avalon and my sons Honda as well. If it weren’t for this jewel, I might have given up getting the shark up for necessary inspections on account of the the labor.
Thanks Tony that's such a good idea and I feel daft for not thinking of it. I like to do things right, and when you're on your own in garage it's a pain to keep walking to other side of car to check alignment of the ramp/blocks with the lift points, but this is great way to correctly position ramps longitudinally and horizontally once the first one is positioned. I will be cutting my 43.5" stick asap!
Safety and Time: two tremendous factors to consider!
I can have my 86 at full lift in under 5 minutes - AND rock solid stable at that! One mistake on the jacking & jackstand merry go round would cost me much more than the security of the QJ. The time savings is simply a huge bonus!
Scott
Scott
I think it would be too cramped under there for a creeper. Never attempted a tranny or TT drop so not sure, but if anyone here claims to have done those jobs successfully on stands than it would be OK. There are limits to something with a relatively low lift height, but it is fantastic to get the car in the air so quickly and easily.
Source = Pickup World
The pic says coming soon but you can buy them direct on the Bendpak website though they deliver from China and there have been a few delivery issues as of late. Personally I have both the MD-6XP and GP-7LCS at home and use a mechanics chair under the 2 post lift to do everything I need. If you end up going for any 2 post lift, just make sure you get one with low profile arms so lifting your 928 is not an issue.
If you can't fit the 2 post, the scissor lift is an excellent alternative if you are looking for a little added height.
I use a Quickjack 3500 which I made lift bars for so it would work on my 928. My '78 is well under the 3500 pound limit but later 928s might be over.
https://rennlist.com/forums/928-foru...a-928-a-2.html
I have ended up using the lift bars on all my cars because it gives a lot more flexibility in placing the rubber blocks, The 944 (and my 924S) has a central lift point on each side plus reinforced points front and rear that are not supposed to be used for jacking (it seems they were used for support on the assembly line)... with the lift bars I can catch all 3 points. The Boxster lift points are very close to the wheel wells so the 3500 is too short and the lift bars are necessary there also.
The other advantage of the bars is that I have marked where to place the rubber blocks for my 3 cars so I don't need a stick. These marks along with my instruction sheet, which details where to place the Quickjacks vis-a-vis the car, makes setup quick and efficient.
I just finished working on my 924S, including removing the transaxle which came out with room to spare.
Lift options
could you use porken bars with the quick jack to gain extra height ? This lift looks great for function but almost looks like it's only good for oil change at best
I just got my Quickjack back from a buddy and I couldn't be happier. 21 inches of clearance between the ground and the bottom of the car! Time to re-attack those frozen starter bolts!
Any sales going on for the 5000? I'm in the market. Costco not on sale right now.
I guess ~$1100 is the regular Costco price, but it's the lowest I've seen, by far (save a couple days ago, when it was $100 cheaper and I ALMOST pulled that trigger...)
pulled the trigger this morning. Can't wait to try it out. Have a bunch of cars to use it on, so it should come in handy.
You won't be sorry.
Chronic Tool Dropper
The common comment from folks who have added lifts (of any sort...) is that "I should have done this a lot earlier!".
