32V engine parts, 1985
Very good parts from my Platinum 85 car that had a valve chain derailment during starting:
Timing parts have approx. 22K mi since new, pics will follow:
Pair timing gears, bolts/washers, $275 pr
Oil Pump gear, aluminum, with nut/washers $55
Crankshaft gear, steel, teeth not worn, + belt guide washers, $70
Tensioner, rebuilt, pliable boot, held oil great, ready to go, $135
Aluminum Inspection Covers, R&L, $80 pr
Center cover, plastic, perfect, $75
Center "underneath" cover, behind the idler wheel and crank pully, plastic also perfect, $70
Also --- 15mm Porsche spacers w/studs and steel lugnuts, 951.331.661.02 --- these are excellent spacers, $150
Cam timing gears if in good usable shape?
and these other bits too
1. Pair timing gears, bolts/washers, $275 pr
2. Crankshaft gear, steel, teeth not worn, + belt guide washers, $70
3. Center cover, plastic, perfect, $75
Please PM or just give me a call, thanks!
Dave
Dave
