928 Forum 1978-1995
Sponsored by: 928 Specialists
86.5 Pod Project
Old Jun 16, 2017 | 10:19 AM
Crumpler's Avatar
Crumpler
Default 86.5 Pod Project
So essentially, procrastination breeds efficiency... if one waits long enough to repair something. Other things will fail and you can solve a lot of issues at once right?
I lost the odometer gear function a few months ago. I put that off, but now it's time. I plan on hitting a lot of stuff while I'm in there.
I need to work on the absent left turn signal cancel.
I have a new ignition switch that I will be putting in finally.
Intensive washer button has fallen apart and will be replaced.
After reading Wayne's write-up, I just decided to just get a new printed circuit, which is coming from Roger.
For the pod itself, I have a new Bob Budd cover.
I was in there several years ago to clean contacts and replace bulbs. But I still have plenty of bounce on some needles, and the oil pressure stays pegged -- until of course it's been run hot and brake pedal used.
I also have a one volt difference between the voltage gauge and the CE.
The tach reads about 75 RPM too high.
I could go on...
I assume that I have issues outside of the cluster too, but I'm not ready to replace any harnesses yet.
I will get some pics up as we go.
How about some pearls of wisdom from my shark-brothers ahead of time?
Cheers.
Old Jun 16, 2017 | 10:21 AM
bureau13's Avatar
bureau13
The voltage gauge has a little adjustment screw you can access if you pull the gauge...just set it to match reality. That's the easy one :-)
Old Jun 16, 2017 | 10:41 AM
Koenig-Specials 928's Avatar
Koenig-Specials 928
Just be prepared for when you re-install the pod (after all your repairs are done) that the stuff you repaired works but now other stuff don't work, like the pod lights all of a sudden goes dark on you (not all the bulbs are now lit).
Ok fine, yeah I'm venting ☠@✴#ing . But be prepared. Just saying!
Old Jun 16, 2017 | 12:03 PM
Crumpler's Avatar
Crumpler
Jeff, that's awesome. How did I not know that?!
Ahhhh yes, fully prepared Fred...
I too, know the bitter, metallic tang of bile as my work goes sideways.
Step one: nausea
Step two: fury
Step three: apathy
Step Four: acceptance
Step Five: financial hit, see step one...
Old Jun 16, 2017 | 09:04 PM
Crumpler's Avatar
Crumpler
Old Jun 18, 2017 | 07:20 PM
Crumpler's Avatar
Crumpler
Only one tricky area getting the printed circuit on, making the fold and getting the tabs back in on the center multi-tab was a pita.
I re finished the console in grey which fits with the other interior work. I also hope it will increase the ambient light somewhat. I did not do LEDs this time but did redo the mirrors for the light set up.
