FS: Used Delrin Rack Bushings
Just pulled from 87 as I have gone back to stock.
SOLD
SOLD
Interesting discussion ... I had Delrin bushes in my old rack, and when Sean replaced it he recommended sticking with the new OE bushings and not re-using the Delrins.
Couldn't really tell much difference, steers beautifully either way.
I think I'll remove the Delrin bushings and install new OEM. Reason - the thick shoulder of the Delrin bushings lower the rack, setting the steering wheel off a few degrees...and probably the toe angle (?)
If the factory bushings are good, leave them in. I'm not a fan of trying to remove brand new bushings to put these in. I've had delrins in my car (Rogers version 1) and after 8 or so years, still love them. If they are shot and the rack is still good, toss these in and you will be the better for it.
Does the extra vibration come in through the entire dash, or just the steering wheel. I figure a mod like this is probably only really worth it on a manual car
I've never noticed any vibration on any of the cars I've put them on.
The Delrin just increase your "road feel" they don't increase vibration that isn't there already. I love mine, but will admit, I'm a touchy-feely driver. I like the added sensitivity. I also am a total fan of the Eibach-Biltstein setup on the suspension which others have criticized as a bit harsh. It's a little stiff to be sure, but the handling I've got now (with good tires) is frankly obscene.
It's a personal thing. Dial it as you like it.
