928 Forum 1978-1995
Sponsored by: 928 Specialists
5 spd conversion..No turning back...
Old 07-19-2017, 01:23 PM
Tom in Austin
Tom in Austin's Avatar
Wow, that is one manly project! Congrats!
Old 07-19-2017, 04:09 PM
AO
Supercharged
AO's Avatar
Awesome job! My Coke car started life as an auto and one of it's previous owners (Constantine?) did the reassignment surgery.
Old 07-19-2017, 05:10 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
... Officially referred to as an "adastictamy"
Old 07-22-2017, 09:36 PM
Hold On
Hold On's Avatar
Originally Posted by Mrmerlin
glad it worked out,
can you post clutch master cylinder install pictures and part numbers
The clutch pedal is a Wilwood floor mount #340-138-33 with a compact integral M/C. Everything is inside the car. The fluid line drops down thru floor and runs along bottom under exhaust heat shield to same location as stock line then up and over starter. You can just see the M/C under the carpet. I trimmed out all the insulation and put the unit up against the firewall leaving just enough room to take cap off M/C I have about 100 miles on it and it works great. Looks weirder than it feels.
Old 07-23-2017, 01:05 AM
whiteNSXs
whiteNSXs's Avatar
That's awesome. For a while, I was thinking about this set up to convert a automatic 928 but never had the time and knowledge to partake so I bought a manual 86.5 instead. Great job.
Steve
Old 07-28-2017, 10:20 PM
Hold On
Hold On's Avatar
I have put some seat time in on the 5spd conversion. I feel like I have rediscovered the car. I drove it for years with the auto and its an awesome car. Now I feel like I got a brand new version of the car I loved. I`m much more a participant in the drive than before. Lovin it.
Old 07-29-2017, 11:25 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,355 Likes on 1,320 Posts
thanks for the pictures,
a new upgrade is the Greg Brown flex line for the slave ,
this removes the convoluted routing of the flex and hard line ,
well worth the price of admission
Old 07-29-2017, 12:26 PM
Hold On
Hold On's Avatar
I eliminated the flex line portion. Plumbed it with hard line from M/C to Slave with one easy to reach union between below floor. Amazing what you can do with a tubing bender and a flair tool. It was a breeze to bleed.
Old 07-29-2017, 04:06 PM
Weissach
Weissach's Avatar
Man, that does look weird. Do you have pictures without the carpet?
Old 07-31-2017, 12:48 AM
jon928se
jon928se's Avatar
Did I read that right ? you only have hard line between the M/C and Slave. If so that solid line isn't going to last very long trying to accomodate the movement of the motor relative to the body of the car.
Quick Reply: 5 spd conversion..No turning back...
