Car came to life and drove away from me at the car wash. Help?
I watch a "tech" spray WD40 into the 14pin connector with the battery connected, after I suggested he unplug the battery first
Starter started to crank, car was in gear, it leaped forward a bit and stopped, scared the crap out of the two guys standing in front of it under the hood
No matter what when I found those wires the first thing I did was order a new harness. Even if that wasn't the problem, It needed to get done. So I'm going to put it on, and see what that fixes.
Developer
Great picture of a typical early engine wiring harness in today's condition.
In your picture, I can see what looks to be melting and fusing of the wires near the top. As has been said, the yellow wire runs to the starter which will crank if it can get voltage from anywhere.
There are two opportunities for this with the engine off. The large red wire from the forward battery post is in that loom, and it is always hot. Then there is the alternator exciter wire, which is blue, but as it ages it turns green. I believe on the early cars it is always hot also.
Thank you for your order, we are making your new engine wiring harness right away today.
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Wow! Nice save! Clearly that harness needs some replacing. Good luck on your repair! I hear new harnesses make a night and day difference with the functioning of other systems in the car too.
Maybe it's just me, but why are you leaving the car in gear?
Neutral and parking brake is how I park mine, unless I'm on a fairly steep grade.
Thanks again for the quick replies and everything Carl.
Thanks for all the help guys, I'm thinking since the car is down I might as well do some stuff like rebuild the steering rack.
Developer
I don't know if that's a bad habit. I was taught to always park a manual trans car with the trans in 1st or Reverse, and with the parking brake on as well. Just habit now...
A few years back there was a local news story about a guy who parked his car in gear and jumped out to run back in the house to get something.
One of his children accidentally bumped it out of gear and it rolled down his driveway, across the street, and into the front of his neighbor's house.
The kids survived but were injured pretty badly. The car was totaled and did lots of damage to the house.
---> Leave it in gear, or leave it out of gear, but ALWAYS set the parking brake...
But it makes me wonder what would have happened if this had been the case in Tamaren's situation.
Surely the starter would not have the leverage to overrun the parking brake (that seems very doubtful).
So I assume the energized, but stalled, starter attempting to turn would just blow a fuse..?
Electron Wrangler
Alan
Electron Wrangler
^ This is how I've always parked all of mine (and taught my two sons the same). As you say, it's a habit.
And - there is no fuse in the starter circuit... there never is. The only thing to blow here is the starter motor or the battery
Alan
Administrator - "Tyson"
It depends on where you live / grew up. Around here nobody uses the parking brake, why? We've all had one freeze up in the middle of winter.
This is especially true for anyone driving VW/Audi's with the locking parking brake caliper. We actually remove the parking brake function on those cars since they can fail, locking up the caliper even if you don't use it.
Just got done with my 30-minute test drive with the new wiring harness. Fixed the problem of not running and made the car a lot happier- gauges are much less sluggish as well. Thanks to Carl from 928 MS for quick turnaround on a new harness, great quality as always and the labels were a godsend.
Moral of the story, check your wiring harness.
