Emissions testing
Just took my Cayenne for its first annual inspection- something required over here when a vehicle reaches the age of 10 years from when it was built [not registered].
For the first time the authorities have seemingly introduced exhaust emission measuring kit - probe up the exhuast type of thing- taken at idle speed only- the Cayenne passed no issue. However I am now worried about what will happen when my 928 is due for testing come next October. The thing has always seemingly had lots of emissions compared to my other vehicles and quickly gets unpleasant in a confined space. I presume they will be measuring CO content but I suppose they could also be reading CO2 and hydrocarbon emissions.
I can tweak the air fuel ratio at idle using ST2. As I understand the car emits 0.5% CO at an AFR of 14 to 1 so I tune for that AFR. I do not have an air pump fitted and as I am aware those things were intoduced to blow air into the exhaust and thus reduce the CO content- something of a bodge to get around legislation of the day. As I understand the CO content can be reduced by increasing the amount of fuel added at idle.
Much appreciate any thoughts based on those who have specific experience of pollution control. Obviously if they are only measuring CO I can tweak the AFR a bit- just do not want to do something stupid and make matters worse. The authorities here are pretty decent and I do not want to fall foul of them. At the moment I do not know what the impact of having no air pump is.
Rgds
Fred
Rgds
Fred
In the states if no air pump = instant fail and no test is even performed. Othr than that I have had cars (not my P cars) pass with de-veined air pump and one with an obviously gutted cat. It depends on how observant the tech was. It is much more strict now, but it seemed many cars can pass with some faults in system.
In Sweden they do not know if there should be an air pump or not. The technicians are not very well informed of a rare car like the 928. I have removed the air pump on all three cars. On the two S4 cars, being privately imported from Germany, I removed the catalytic converter before the Swedish registration. I got them approved as non-catalytic cars which made me very happy.
Åke
Åke
Agree with the above comments. Most techs will not even know about the air pump. They'll look under the hood, hook the 'sniffer' up and if that and the gas cap pressure test works out, you'll probably be fine.
I am not expecting any awareness of what should or should not be there but I would like to know what parameter they are likely measuring [CO] and the likely acceptance criteria. I have asked a friend to look into the matter and beyond that I want to minimise whatever it is they might be looking for.
Previously they asked you to rev the car and they would make a visual looking for a smokey exhaust- now it is going to be more subtle but I suspect nothing like the smog tests in the States for instance.
Indeed now you made me think a bit if the thing did fail on the day I suppose I could ask them to let me tweak the adjustment pot to suit whatever might be wrong- the local constabulary are generally very friendly and helpful believe it or not.
Here are worldwide standards with regional breakdown. I think this can give you some direction. Quite detailed.
http://delphi.com/docs/default-sourc...uty-2016-7.pdf
cheers and hope it helps
Rgds
Fred
Rgds
Fred
I just ran a 3yr parked 83 in california across emissions, and with goopy leaking intake donuts (spider intake) and everything else in the path of hydrocarbons clearly leaking and collecting dirty (all goopy too), AND an audible, we think, intake leak from a cracked intake boot...
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_1752_8b108ee1ccb828761d4c052f4eadd965f022a20b.jpg)
Chronic Tool Dropper
Fred--
More fuel = more CO. Not enough fuel gives higher HC as you get to the point of lean misfire. Not enough fuel will also spike NOx as you start having local hot-spots in the chambers. With no cats originally fitted, I'm not sure what they really expect. Leaded fuel is tough on oxy sensors too, FWIW. So after you get the mixture lined up with your ST2 and WB sensor, probably a good idea to plug the sensor hole until you are actively looking for data again.
Inventor
Thus my heap is a non cat with open loop CO control.
The air-pump on the cat cars injects extra air into the cats and is only needed during cold start. Unlike other makes with electric pumps which run only for a short time (or older Mercedes with clutched air-pump pulleys) the 928 air-pump is just a parasitic drag most of the time for O2 sensor equipped cars.
Fred--
I suspect they are really looking for wrecks that chug all kinds of gunge out to avoid accusations of impartiality. Maybe I will set the idle AFR at 14.7, then note the adjustment to get it to 14 so I can adjust on the fly as it were. If that does not do it then I will be well and truly in the smelly stuff.
I have often wondered why they would fit an air pump on a non cat vehicle. The air pump on mine made some suspicious noises about 15 years ago and my friendly chief mech suggested I might consider "deletion" but my decision of course.
Rgds
Fred
