Vacuum line missing.
Not sure if I'm missing the other end or if gets capped off, can't find any loose lines is it supposed to be bare like it is
Trying to still source the root of a stiff brake pedal. 85s3 5 spd.
also is there a test for the venturi that leads to the booster.
I believe that is a test port, and no line is missing.
I have a Tee on my '80. One goes to the brake booster, one to the cruise control, and one to the HVAC. The other end is a capped test port.
correct, test port. I hook my mighty vac in this spot to test operation. very good spot. One line goes to vacuum canister, other tees into the dash for AC and I forget the location of the third. At least on my 80.
If you remove it you may go back with new rubber. On mine the old rubber would not hold the plug once I got it removed.
