Brilliant, yet often overlooked tools...
#31
Sean,
That relay tester would be great in saving lots of relays without unnecessary replacements. Do you know if there is any significant difference between your ES 190 vs the ES 192? Looks like the ES 192 tests 24V relays too, but we don't need that, right?
thanks-Hoi
thanks-Hoi
#32
No clue on that as this is the only one I've played with. Sorry.
#34
Tap, drill chart.
These are helpful too.
#35
It's funny- I have 5 of the first 6 tools in my arsenal, just bought the 'Otto' bar easy-stick yesterday on his recommendation. The following tool I have found indispensable- it has a magnet on the end so sticks to anything steel, the COBB LED unbelievably bright - this is a tool I use every day...
https://www.amazon.com/Nebo-Flashlig...=big+larry+led
#36
Chronic Tool Dropper
#37
Ummmm... For pre-S4 cars without the full belly trays, you can just reach up from underneath.
The new-and-improved version of this wrench will just have a square-drive on the bar, so I can put a ratcheting adapter between it and the socket.
#39
Valid point, but I still think the S4 guys get all the cool toys
