'79 Manual: Ignition Switch Problem?
Omg Hoi! I had found the exact same thing on #30 when I bought it. Took me a few days to figure it out, because the guts were ripped out of the starter button. I replaced the ignition switch and did away with the push button.
The other button is the intensive washer button.
hi Ron,
I probably will keep it. Too lazy and scare to mess with a working switch.
Update: the car is actually running pretty good. I think it didn't have much gas in the tank after I got it started earlier. After putting some Techron and more gas in it, it is running pretty well. Adjusted idle back down to 750-800 and it idled fine.
Now, on to the fluids change....
thanks to everyone for the help!
Andrew, you are the best in helping me test the circuit. Will save the instructions for future cars![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
-Hoi
-Hoi
