New To Me Rough Idle When Cold.
Did what Jim recommended. Added 32 oz. MMO to oil and let idle till at the first white line of temp. Initially it needed a little help but then held its own. Turnt it on & off and start ups did not have the asymmetric/missing kind of issue.
My fingers are crossed.
Going to get new plugs.
What is the latest recommendation on plugs these days ?
I've always used the Bosch wr7dc+.
Team Owner
swapping the coil wires . means to the each coil to distributor cap wire.
you have 2 coils dont let the coil wire rub on any metal or it can short,
make sure the ends are clean
for a plug to have oil on the outside of the plug,like in the picture
oil has to be leaking down the plug well from the cam cover seal.
when you unscrew it then the oil will get on the threads
If their was a significant amount of oil in the combustion chamber then you would see lots of smoke from the exhaust pipes.
Team Owner
check the ends Beru set has 4 coil wires ,
only two will work.
BUT the wrong ends can be removed.
put a thin screwdriver into the boot then spray some silicone into the boot then unscrew
only two will work.
Waiting for the new plugs, but did switch coil wires today. Same scenario present though hit or miss on occasion. What I mean is on one startup she'll run rough. Will turn off and restart and find the initial idle and running are completely smooth and normal for 5-10 minutes then suddenly will go up and down between 400-100 and when low enough will stall.
Team Owner
check the throttle cables for proper slack and that the TPS is clicking off for the idle circuit
