Window motor connections '79 / '80
Does anyone have a picture or information about which two pins on the window motor ('79/'80) are used for up and down? Based on the scratch marks I am guessing the two closest to the camera but I'd rather get it confirmed before applying power
Cheers!
Carl
Cheers!
Carl
it won't matter- it is either power or no power. Test and see. Plug in and activate the switch, and see what happens.
I'd use the ohmmeter on it and see what's shorted together. The switch toggles the relay to connect power "+ and -" or "- and +" to make it go down or up. If it's not in sync with the switch, reverse the connections at the motor.
