CIS. Chasing a vacuum leak?
I did it 3 years ago prior to the new engine. No issues removing the screws but I do recommend using a quality snap on or similar screw driver. They are fairly soft.
kiwiokie, I recently rebuilt the throttle body in my S3.
The screws were peened on the backside. They came out no problem with slow, steady pressure unscrewing, and keeping the tip of the screw driver pressed firmly into the screw head.
As I could not find suitable replacements, I chased the screws with a die, 3mm I think. When I reistalled the screws, I used green Loctite 290 on the threads.
Good Luck!
Good Luck!
