My first TB, i think I need help....
#34
Just to tell to all the people who came here to help me(included greg brown), i did it. Passenger cam is 3mm retarded, drivers side cam is ok. I will get Porken tool to setup properly cam timing. I spent actually all the night to clean an rebolt parts and doing all the "while you're at it ''jobs, Putting the baffle under oil neck, ans so on... I loaned a compression test tool and will see if i bent valves. I will tell you if this odissey has a good end or not. Thanks for your support.
Francesco
Francesco
#35
Francesco
Francesco
Where do the cam timing marks sit relative to where they were before you started?
If you acquire the 32VR kit recommend you also purchase Ken's Bumpstick kit- makes cam timing so easy. I recently changed out my cam sprockets and thus had to redo the cam timing. Once I had everything out of the way I removed the belt, changed over the sprockets, fitted the belt, did the cam timing and torqued the cam bolts in less than an hour all without any assistance.
#36
I think that Porken stuff for timing is an high vslue for 928 owners... I will buy them.
My mechanic tomorrow will give me a compression tester. Do you know what values i could read with cold engine( apart i never should not read 0 psi)?
#37
When we tested my motor with two bent inlet valves on No7 there was literally no pressure build up so not much chance of making a mistake. Just follow the tips I posted earlier.
#39
Just to tell you that everything went fine... Valve lifter were empty of oil after 4 months, it is a bit tappety.... But everything is fine.
Compression, just for reference, was in the 155-165 range, cold.
#41
Yep, in fact at operative temperature, i can barely hear only injectors clicking noise. Lesson learned :read read and read again experts tutorials. Then read it again and try to understand what you read. No doubts ? Chances are 1 you have not read enough 2 you 've asked yet to rennlisters 3 you wrote that tutorial.
Thanks again.
P.s.: now 7,30 a.m., tonight i slept without the timing belt nightmare i got into.
Thanks again.
#42
I've been watching this thread and hoping for the excellent result that you got.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
It's just before dinner time over here, so I will be celebrating your success with a couple of glasses of vino.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
