82' 928 Power Steering Hose Needed - 928 347 449 02
I have a leaky power steering hose with part number 928 347 449 02.
It appears to be longer available. Does any one have one or is there a creative solution to replace the part?
Kevin
Kevin
The life of the low pressure line can typically be extended by cutting an inch or so off the end that attaches to the fluid reservoir.
For the high pressure line have the hose remanufactured at your local hydraulics shop. They'll take the old fitting off and install new hose.
Be sure the fittings are clocked correctly!
I took my old one to the local "Pirtek" people, they used it for a template for a new one and also fitted a "universal" coupling mid line to orientate it during installation. (5 years ago)
