Early Engine Vibration dampers
I'm replacing my engine vibration dampers (engine shock absorbers) on my 1980. I cannot find a torque spec for the bolts. Can anyone point me in the right direction?
Thanks as always!
Thanks as always!
torque is not really important. just tighten by hand on your own feeling. btw : I used the engine vibration dampers of a Mercedes 190 model of 1983. Cost per damper = 40$ instead of 120$ for original Porsche dampers. You only need to put some shims at the top fixating.
It can't be. This is German engineering. Everything must have a specification!
Basic Site Sponsor
Basic Site Sponsor
10mm bolts (17mm head) grade 8.8 = 32 ft lbs.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Check the mounts at the same time, if you haven't already replaced them. If the top metal bracket is no longer attached to the rubber (the rubber is vulcanized to the metal, originally), they also needs to be replaced.
Basic Site Sponsor
Basic Site Sponsor
The mounts control most of the movement. The shocks slow the movement down. The fact that your bushing are completely gone probably means the mount themselves have been broken for years and the shocks have been doing the mounts job.
However, one never knows with these cars. Someone could have replaced the mounts and left the worn out shocks in place.
