928 Forum 1978-1995
Sponsored by: 928 Specialists
Terminal Points
Old Nov 2, 2003 | 04:23 PM
Sphin's Avatar
Sphin
Default Terminal Points
Hey Guys, I am trying to run a jumper wire to my fuel pump by doing the procedure mentioned on many other threads by jumping terminal point 15 to 87. I think I may have a bad relay. My question is where are these points on the relay panel? I cannot seem to find any mention in the wiring diagram as to these points.
Is point#87 one of the plug in points on relay xx? (other thread seems to indicate this). Appreciate the help.
Sean Phinney
86 Prussian Blue
Old Nov 2, 2003 | 04:33 PM
John Speake's Avatar
John Speake
Sean
When you pull the relay, you will see a little diagram on the side of it, with the terminal numbers. You need to jump the terminal on the relay socket across what is shown on the circuit as the "normally open" contacts.
i.e. the ones that close when the relay is energised.
Old Nov 2, 2003 | 04:48 PM
Sphin's Avatar
Sphin
Thanks John, How about that, printed right on the relay! Never would have known otherwise. I assume that if the pump operates after jumping these two terminals my relay is bad.
Sean Phinney
86 Prussian Blue
Old Nov 2, 2003 | 05:42 PM
ErnestSw's Avatar
ErnestSw
Correct
