928 Forum 1978-1995
Sponsored by: 928 Specialists
ABS/Pad wear sensor bracket
Old 11-21-2016, 03:57 PM
bureau13
bureau13's Avatar
Default ABS/Pad wear sensor bracket
I've asked about this a couple times, and ordered parts to fix it, but haven't been able to get an answer that matches what I see on my car, however people are talking about ABS loom failures, etc in other threads, so maybe someone has recently taken a fresh look.
On my PS front wheel, there is a bracket that holds the "clamshell" that holds the barrel connector connecting the ABS/pad wear loom to the wires leading to the sensors themselves. That bracket has broken on my car, allowing the clamshell to move about and at some point, the wires got pinched in the suspension and broke off. So, I get a full time pad wear warning, and an ABS warning after I start moving. I have a replacement loom, new clamshell and two or three of what are supposed to be this bracket. Only, that's not what it looks like on my car. The part I have as a replacement is #14 in the PET diagram attached. But I just don't see that anywhere on my front wheel. What IS there looks a lot smaller and less complicated. Maybe I'm misreading the diagram.....but can someone tell me if #14 is present on an '86.5 and if so, is it supposed to be the part that the clamshell mounts on? And if not, what is....#12 maybe? I think I saw a different version of this diagram and there were even more options, i.e. more confusion on my part.
ABS.pdf
Old 11-21-2016, 04:23 PM
davek9
davek9's Avatar
The bracket is spot welded to the inner fender and that plastic assembly(clam shell) is clipped to it, also the ground wire is screwed to it.
Doesn't look like anything you posted in that pdf, I just looked at the two 86.5's in my garage, both have the same tower like structure (two legs and a platform) and are the same as the one on Left side
Old 11-21-2016, 04:28 PM
bureau13
bureau13's Avatar
Sorry...to clarify, this is for the clamshell located in the wheel well (actually attached to the wheel) not the one inside the engine compartment.
Old 11-21-2016, 04:39 PM
davek9
davek9's Avatar
Ahh was wondering that, I'd need to pull off a wheel, could do it later one is already on stands, maybe someone else will respond sooner for you.
Dave
Old 11-21-2016, 09:13 PM
ROG100
Basic Sponsor
ROG100's Avatar
Jeff - Right side is 928 331 240 00
Old 11-21-2016, 10:25 PM
bureau13
bureau13's Avatar
Roger...that's the part for #14 in the PET diagram? That's what I have several of, I just don't see that part when I look at what is currently installed on my car. I tried to get pictures of it before, but none of them clearly show what I'm talking about. Here's the best one I have:
This is on the driver's side, so it's not the one that is broken. It's from the top though, so you can't see much of it.
Old 05-13-2017, 04:22 PM
bureau13
bureau13's Avatar
Resurrecting an old thread, because I got some better pictures of the bracket in question:
This is the intact driver's side bracket. You can see at the top where it's attached to the clamshell connector holder thing
Here is the broken passenger side bracket. Lower side of upper left end in the picture is where the lip that attaches to the clamshell broke off.
This is NOT the same part that I already have three of lol...I can't figure out what it is...
Old 05-13-2017, 04:39 PM
ROG100
Basic Sponsor
ROG100's Avatar
86.5 =
Left side 928 331 239 00
Right side 928 331 240 00
Jeff what is the part number that you have three off
Old 05-13-2017, 04:49 PM
bureau13
bureau13's Avatar
That is what I have (I actually have one of the left side, and two of the right) but it looks like this:
Unless I am losing my mind, that is not the same as what is actually on my car.
Originally Posted by ROG100
86.5 =
Old 05-13-2017, 04:52 PM
ROG100
Basic Sponsor
ROG100's Avatar
OK the one in the picture is the left side correct?
You are looking for the right side (passenger side) correct?
The right side is a lot different to the left side.
Old 05-13-2017, 05:24 PM
bureau13
bureau13's Avatar
The two part numbers listed above are mirror images of each other. I believe that is the case with the pics I took of my car as well. I rotated them so the parts would line up more or less, to make it obvious what was broken.
The pic of the new part above is the left side, in the post with pics from my car, I show an intact left side and a broken right side. The two pics from my car look the same, just mirrored (and save for the broken part) as do the two new parts I have (I can go dig up the new right side part that I have if that helps).
Quick Reply: ABS/Pad wear sensor bracket
