83 928s Intake Refresh Parts List
Please review and let me know what I am missing for an intake refresh...
QUAN ITEM
1 Heater control valve (hot air in cabin all the time)
Set Plug Wires
1 AFM O-ring
1 AFM Sealing Ring
8 Spider leg gaskets
1 Heater hose supply
1 Heater Hose Return
1 Oil breather hose
1 Oil Separator Hose
Set Fuel lines - Precision Motorworks
1 Alt Belt
1 AC Belt
1 Air Pump Belt
1 PS Belt
Vacuum lines and connectors (bulk)
Rebuild Fuel injectors
Shorty Fuel lines - local shop to rebuild
Thanks -
-scott
QUAN ITEM
Set Plug Wires
1 AFM O-ring
1 AFM Sealing Ring
1 Oil breather hose
1 Alt Belt
1 AC Belt
1 Air Pump Belt
1 PS Belt
Thanks -
-scott
The term intake or top end refresh has different meaning to different people such that there is no definitive list of parts that make up the refresh. My own definition is any part that needs replacement or rebuilding/refurbishment that is located or crosses into the volume bounded from left to right between the cam covers, from front to back between the distributor and the firewall, and from top to bottom between the air box and the bottom of the engine valley.
Below is a link to a spreadsheet of parts that I purchased for my refresh. It also includes fuel system parts since my car had been sitting for years and needed a thorough clean up in that area. I purchased all GB lines where applicable. Many are the same that you have listed but there may also be some parts that you may want to consider. In addition to the parts on the spreadsheet I also purchased the short fuel lines, plugs, plug wires, cap and rotor and sent the injectors out to WitchHunter.
https://www.dropbox.com/s/63vfuf8hw4...fresh.xls?dl=0
Thanks Nate - I am going to call Roger too and see what his recommendation is. I think my car is very similar to yours in terms of sitting for awhile...
-scott
-scott
