928 Forum 1978-1995
Sponsored by: 928 Specialists
fuel regulators???
Old Oct 30, 2003 | 08:36 PM
onebad928s's Avatar
onebad928s
Default fuel regulators???
has anyone removed both fuel regulators and used one adjustable regulator?
Lou
83 928 5speed
Old Oct 30, 2003 | 08:50 PM
Mark's Avatar
Mark
Check w/Dave Roberts @ 928 Specialists...He has a way to do it with a single rising rate fuel reg.
Old Oct 31, 2003 | 03:59 AM
onebad928s's Avatar
onebad928s
Ok Mark,
Ill give him a call, thanks
Lou
83 928 5speed
Old Oct 31, 2003 | 03:42 PM
Jadz928's Avatar
Jadz928
It is pretty straightforward. You would use a RRAFPR is lieu of the pass side FPR, and a damper (look similar to a FPR) in lieu of the driver side FPR.
There is a vacuum hose that goes to the FPR replaced by the damper. Cap it.
That is it.
Old Oct 31, 2003 | 04:22 PM
Tony's Avatar
Tony
On the 87 and up atleast there is only 1 regulator....and 2 dampers.?
Old Oct 31, 2003 | 06:28 PM
onebad928s's Avatar
onebad928s
Jim what i was wanting to do is get rid of both regulators and clean up the mess of lines and use 1 adjustable regulator.Since on the 83 US 1 regulator feeds into the other.There is also a dampner on the front of the engine (stock). This might sound stupid but what does the dampner do?
Lou
83 928 5speed
Old Nov 1, 2003 | 03:01 AM
urnotthesameina928's Avatar
urnotthesameina928
Question fuel dampner
Hey Lou A damper is critical to the proper function of any EFI setup. Rapid cycling of the fuel injectors and fuel system components in a running engine combine with the non-compressibility of the fuel this can create high frequency pressure waves in the rail. These pressure waves can cause substantial variation in the fuel delivered by the injectors; causing numerous running problems that are difficult to trace, in addition to increasing stress on the fuel pressure regulator. On my 86 like tareks we have one regulator and 2 dampners for our high fuel delivery engines.. I would stay with 2 dampners for each fuel rail.. This is one area I have looked into changing and updating in my car because of some tuning issues will keep u posted..Dave..
Old Nov 1, 2003 | 03:28 AM
TAREK's Avatar
TAREK
Dave,
I think Lou's setup is different than ours
Old Nov 1, 2003 | 03:33 AM
onebad928s's Avatar
onebad928s
Dave,
I understand what your saying but with the 83 there is 1 dampner and 2 regulators(1 dampner splits to each fuel rail,each fuel rail has one regulator)different set up than your 86.5.Im trying to find out if i can lose the 2 regulators and use 1 adjustable high performance regulator.I heard you need some kind of a performance gain (dyno 160) keep trying on the fuel system.;-) playing
Lou
83 928 5speed
Old Nov 1, 2003 | 01:12 PM
BC's Avatar
BC
So would a dampeners want to go FIRST, at the beginning of the fuel rails, and then have one regulator at the end of the rails, letting what it needs by (and into the return system) to produce the pressure required?
Tim Murphy had a fueling issue, as well as the red SC guy, and it revolves around (probably) the fact that the rails are IN LINE instead of TANDEM, and the last injector on the line, at that fueling rate, doesn't get as much pressure and flow as the rest. I want to plumb my rails TANDEM, and I need to map this out somehow.
Old Nov 2, 2003 | 01:43 AM
Tony's Avatar
Tony
Eh..just plumb up a parallel fuel system...one pump for the left...one for the right.
