Tach. Jumps any advice ?
Any advice would be appreciated. ( 83 928S 5 speed )
Richard
My first guess would be a slipping clutch. If the engine is actually revving
faster (the tach is telling the truth) but the car is not moving faster......the most likely problem is a clutch disk/pressure plate going bad.
Mike , I think that is a great idea , I will check the clutch and pressure plate, that is the feeling the car reves but no power to the wheels.
It is time to start the winter projects anyway.
Richard
Stop the car on level ground and select the highest gear (happened to be 4th he demonstrated on). Take your foot off the brake (don't set the parking brake either) and slowly let the clutch pedal out...just like you would to take off. The engine should die swiftly and quickly without any bucking or other unpleasantness. If it protests in any meaningful way, it is a good indicator that the clutch is not biting as it should and needs to be inspected further.
I have used this technique on several vehicles and it is very accurate. Certainly engine reving under load in higher gears is as well, but this method works when you cannot do this.
Hope this helps.
Regards,
SteveCo in St. John's
