Electric hatch release
Depending what year car you have the 1 amp fuse is blown - try #26 or post the year of your car as it really helps us help you.
In this case there is a defect in the motor itself. Either the connection track for the self parking has smeared across the parking gap. Or rather more likely the brake transistor is fried. There is a documented fix thread for this (transistor replacement) - or you can avoid the future hassles by replacing the whole motor with a better in every way VW actuator - threads on this also. I recommend the latter.
Alan
Another vote for swapping the stock hatch release with a VW unit. You will have to do a bit of fabricating, but the time spent will still be less than what you will consume fiddling with the original hatch motor. If you go the VW route, get the unit that pushes instead of pulls and mount it so it pushes downward.
Here are some resources for this in case you didn't find them:
Same issue reported: https://rennlist.com/forums/showthre...eferrerid=6055
Brake mod: https://rennlist.com/forums/showthre...eferrerid=6055
VW Replacement: https://rennlist.com/forums/showthre...eferrerid=6055
Alan
Alan
Just fixed the same issue, the transistor that brakes the motor fails and it runs on too far and gets powered repeatedly as a result. I went for a mechanical fix and cut some more of the contact away with a dremel. It means the button might have to be pulled up slightly longer to start the motor but it stops after one cycle. There is of course the proper fix to replace the transistor....
Before
After
Before
After
