Broken Manual Transmission
Looking for some advice / guidance.
Driving home the other day, shifting from 4 to 5, I lost gears. I tried putting it back into 4, still nothing. Tried all gears and nothing. I was hoping it was a shift linkage so climbed under car after getting it towed home and linkage entering trans is moving as it should when moving shift ****. I have never had a situation where all gears are gone. I have also not done a lot of transmission work.
Appreciate any advice / input. Plan is to get the car into my garage and pull the trans.
Former Sponsor
I generally skip right over the "user" threads. Giving free advice to free members just rubs me wrong.
Pay a few bucks and join....you'll get way better help!
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Yeah, we are still a friendly bunch. I've met a lot of really nice guys here.
Have you checked your drive shafts? GL
Don
Don
Hi !
Can you even get the car into "neutral" so it will roll?
Did you remove the rubber boot at the trans to be SURE that the rod into the trans is moving ?? and not just the coupler ? The little allen head set screw sometimes comes loose.
Likely that the front plastic shifter ball cup finally gave up and popped off the shift ball. Its a relatively easy fix. As others have suggested, take a look at the front top of the torque tube and see if the shift arm is still attached.
