Upper control arm part numbers
For the later models the UCA part number according to PET is 928.341.027.31 and 028.31.
I have also seen part numbers 928.341.031.31 and 928.341032.31 used ostensibly for the same respective parts. Mch appreciate if anyone can advise whether this is a mistake or whether they may have been used to define later upgraded/replacement factory parts .
Fred
Fred
My presumption is that maybe Porsche changed something in the spare parts spec post production- that or maybe a change of part supplier.
Rgds
Fred
Final call for input:
I have also seen part numbers 928.341.031.31 and 928.341032.31 liked to the same part in a search but not in PET.
Appreciate if anyone can offer any clarity here.
Rgds
Fred
Rgds
Fred
I wonder if the number cast into the arm is an internal number for the arm casting? The number in PET is for the complete assembled arm so perhaps there are part numbers for each piece of the assembly.
Mike
Mike
Fascinating but somewhat confusing I suspect. I was under the seemingly false impression Porsche only stamped the PET number on the part not that of a sub component - do they pull this stunt regularly?
Must take another look at my currently installed arm and check the number I can see [pretty sure it is the PET number]. Then again maybe it is the other number- never crossed my mind to check this given I know my current UCA is the original one fitted in the factory.
Mike- I never would have thought of that one-well done!
Rgds
Fred
Rgds
Fred
