Clutch Control Off Error - 93 GTS
So after the GTS died on me last week, I spent the weekend cleaning up all the CE panel issues. Last night finally had time to take her out for an extended drive just to make sure there were no remaining issues.
Upon starting the car I get a "clutch control off" error on dash. I can clear with the lower left stalk. I have searched and found a couple threads that speak to the PSD as issue but the resolution was replace the PSD unit. So are there any other troubleshooting ideas or fixes? And if not a quick fix, are there any issues with driving to Frenzy next week, it's just under 700 miles each was so don't want to be stranded a long way from home.
I've received that error when the fluid level was low. It's brake fluid that really needs to be changed every few years and is often overlooked. I use Castrol LMA (low moisture absorbing). Hopefully that's all it is, although it could be a more serious issue.
My '93 has a PSD error, but the text is different than what your report. The PO stated that the problem started when he had some aftermarket sounds installed, but the dealer said the pump was bad. I have not investigated myself, but that points to at least some possibility that it is an electrical issue. In any case I drive my car this way.
