Momo Hub Removal Problem
I’m in the process of installing a momo steering wheel on an 85 US. I followed the instructions from previous posts and it went on without incident. Once I was done I took it for a cruise and noticed
that the wheel wasn’t completely straight, it was 10-20 degrees off center. So I started to take it apart to straighten the hub, but now I can’t get the hub off. I tried pulling as hard as I could with no luck, added a
little WD40 which didn’t help. There doesn’t seem to be a good leverage point to pry it off (not to mention what I might bend) Thought about drilling out new holes in the hub, but that means I’ll never be able to get the
turn signal stalks off again either. Before making this problem worse I thought I might ask if anyone has had this problem or suggestions?
Hmmmmm. I recently installed one and had to pull it out again when I put the LEDs in the POD. As I recall, it was a bit tighter than the original. I think I rocked it from side to side just a bit (pulling on the left then on the right) to get it started.
