928 Forum 1978-1995
Sponsored by: 928 Specialists
High pressure power steering line leak.
Old 09-06-2016, 06:21 PM
Tony
Tony's Avatar
Default High pressure power steering line leak.
Well, what i thought was a leak from the LP line is in fact from the HP line. Over a period of a couple of days i got the car up ..cleaned..then drove...then inspected....rinse wash repeat a few times. Looks like very tiny leak just prior to the fitting. I cleaned the hose off and got it completely dry, plugged one end and ran some air through it.....sure enough under some pressure a bit of residual fluid came to the surface of the hose. seen below.
also...what is the purpose of the metal "crimped" part on the HP line. I was under the impression the restriction was located elsewhere?
my car is pretty damn clean underneath and even so , this job is a PITA.
the rubber shroud was over the hose PLUS i have an extra home made heat shield protecting the area.
Old 09-06-2016, 06:34 PM
Koenig-Specials 928
Koenig-Specials 928's Avatar
Just take it to any of the truck hydraulic repair businesses in your area. Will cost next to nothing to put newer hoses on with your own fittings. That's what I did 8 years ago and still going strong
Old 09-06-2016, 06:46 PM
Randy V
Randy V's Avatar
There's been several mentions of the purpose of that restrictor in the line. The leading one seems to be it's some method of reducing noise from the hydraulic system.
My experience in having a new hose manufactured, reusing the existing hard lines and deleting that restrictor resulted in a noticeable improvement in low speed turning ease without any negative effects.
Old 09-06-2016, 07:30 PM
mj1pate
mj1pate's Avatar
What I hear from the "old hands" in the forum is that the restrictor reduced the amount of power assist and offered greater opportunity for steering feedback.
Btw: a good hydraulic shop should be able to crimp hydraulic hose onto metal fittings that will last. I've had good results so far
Old 09-07-2016, 07:17 AM
jpitman2
jpitman2's Avatar
I had a leak in the HP line a while ago, and had them all rebuilt locally, with no issues. Having seen the potential for fire here, I covered the HP hose with a protective sleeve (Ryco Firesleeve) which will reduce the heat experienced by the hose, and if it does leak, channel the oil down past the exhaust manifold so it doesnt spray everywhere. Have also covered the fuel lines on the other side.
jp 83 Euro S AT 56k
Old 09-07-2016, 07:57 AM
Landseer
Landseer's Avatar
Timely post, priced new replacements at 250 ish.
Anybody have an estimate of pressure requirement?
Steering pump has 75 bar stamped on the tag. That's over 1000 psi, isn't it?
If true, its no wonder we have fires.
Old 09-07-2016, 01:18 PM
Tony
Tony's Avatar
79 bucks..its back on the car and up and running. Crimped fittings and 2000psi hydrualic/PS hose. Same place that has done all my other hoses.
RV..it does feel a bit lighter, may be its just me. I have the smaller momo wheel which makes turning a bit harder anyway, but it does feel different.
Old 09-07-2016, 01:39 PM
FredR
FredR's Avatar
Tony,
Did you abandon the restrictor or reinstate it?
Rgds
Fred
Old 09-07-2016, 06:57 PM
Tony
Tony's Avatar
Originally Posted by FredR
Tony,
Rgds
Fred
If that crimp is indeed the restrictor...its not on the hose now. Steering is lighter..not much but i like it, espcially with the steering wheel i have.
Old 09-08-2016, 04:54 PM
soontobered84
soontobered84's Avatar
My understanding is that the restrictor's function was to reduce the groan sound that happens periodically from the PS system.
Old 09-08-2016, 04:57 PM
BIMMERMIKE
BIMMERMIKE's Avatar
Which "truck hydraulic repair " do you use?
I have a unit which requires repair but not urgent.
Old 09-08-2016, 05:11 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Mike,
You can take it to any local hydraulic hose repair shop.
Old 09-08-2016, 05:14 PM
BIMMERMIKE
BIMMERMIKE's Avatar
I visited a couple places years ago and didn't want to repair.
Everything is good but would like to have old unit repaired in case of future issues.
Originally Posted by Imo000
Mike,
Old 09-08-2016, 07:54 PM
Adamant1971
Adamant1971's Avatar
Received 1,027 Likes on 491 Posts
Fluidline will do it.
Old 09-08-2016, 08:57 PM
Koenig-Specials 928
Which "truck hydraulic repair " do you use?.....
Yes, Fluidline on Wyecroft in Oakville
Quick Reply: High pressure power steering line leak.
