FS - 1980 Porsche 928 Service Information manual
I'm selling an original Porsche 928 Service Information Model 80 manual. It's publication number 4592.21, is 86 pages and includes sections on:
Asking $45 shipped in the continental U.S. Paypal preferred.
Thanks!
- Engine versions for the 1980 model year
- Engine - Pistons, Cylinder Heads, Valve Train, Miscellaneous
- Fuel System - A.F.C. & System Diagram, Lambda Control, Oxygen Sensor, A.F.C. with Oxygen Sensor, Ignition, Exhaust
- Power Flow - Clutch
- Chassis - Front axle/Wheel Alignment
- Body - Air Conditioner, Doors
- Electrical System - Center Console/Switches, Instrument Cluster/Switches, Central Electric (CEL) Wiring Diagram/Vehicle Wiring Diagram/Central Electric Board Wiring Diagram, Front End/Engine Wiring Diagram, Passenger Compartment/Instruments Wiring Diagram, Rear End Wiring Diagram, Air Conditioner Wiring Diagram, Radio Wiring Diagram
- Fuel Supply
- Fuel System
- Ignition System
- Technical Data on Engine, Powertrain/Chassis/Brakes, Wheels, Tires, Dimensions, Weights, Capacities, Performance Values
- Diagrams - 5spd Manual and Automatic Transmission
- Identification - Changed Chassis Numbers for 928, Identification of Numbers 928 Model Year 1980
Thanks!
Last edited by JWise; 09-02-2016 at 11:08 PM. Reason: Corrected to read "4-hole punched"
I'll take it Jarrod.
You got it! I'll email my Paypal address.
I believe I already have your mailing address.
Thanks!
Thanks!
Munee sent.
Received. I'll get the manual mailed out in the morning. Thanks again!
JW
JW
